It is currently Wed Jul 01, 2026 4:35 am
[ 5 posts ] |
rhopkins
Post subject: Speedo Posted: Tue Jun 07, 2011 2:02 pm |
Hi to all. I have an 09 a22 and the speedo is acting up. it onlys reads half speed say im at 3000 rpm it only reads 10 mph when it sholud be around 20 mph 5000 rpm it on reads 22mph and it use to read 42 mph. I was woundering if anyone has a wiring diagramto these things. Thanks
Walter
Post subject: Re: Speedo Posted: Tue Jun 07, 2011 3:12 pm |
Check under the boat and see if the small paddle wheel has anything stuck in it, should be in the middle about 3-4 feet from the rear, might just have picked up a piece of fishing line causing it to turn slow
rhopkins
Post subject: Re: Speedo Posted: Wed Jun 08, 2011 1:16 pm |
A new wheel was installed... and still the same thing.
DarthWader
Post subject: Re: Speedo Posted: Thu Jun 16, 2011 7:53 pm |
| Axis Owner |
Joined: Fri Jun 11, 2010 9:35 am Posts: 92 Location: Gig Harbor, WA
might be a bad speedo?
_________________ 2010 Axis A22
morrisdl
Post subject: Re: Speedo Posted: Fri Jun 17, 2011 9:33 am |
I have you tried spedo recalibration?? I think it is holding the down arrow for 3 seconds while the display is on engine temp. Im not positive its "engine temp", you may have to try others. Each display (lake temp, air temp, engine, psi, etc) does a different thing when down arrow is pressed for 3 sec. I took a gps out and adjusted it at surf speeds and wake speed, and seems good though out the range now. Mine was reading +2mph
[ 5 posts ] |
Users browsing this forum: No registered users and 26 guests |
