It is currently Sun Jul 06, 2025 6:34 am
 Post subject: Re: axis 2016 T 22 surf
PostPosted: Mon Mar 07, 2016 2:43 pm
Not trying to start any crap here but why are you guys saying to weigh down the surf side? By listing the boat you are pulling the gate out of the water and making it less effective. I have tried it and noticed no significant gains. The best adjustments is the bow weight depending on rear ballast, crew and wedge.
PostPosted: Mon Mar 07, 2016 2:51 pm
From your description it sounded like you were trying to surf the side that the paddle kicks out on. Just wanted to make sure that wasn't the case. I've never see a boat with Surf Gate not have a clean wake even with no weight in it.
PostPosted: Tue Mar 08, 2016 10:49 am
We primarily surf the port side and the wave most certainly has more 'push' with the boat slightly listed (ie a few crew members adding up to ~500-600lbs)
When surfing starboard, I do not need to position the crew.
2018 T22
PostPosted: Tue Mar 08, 2016 8:09 pm
+1. When the boat is even the starboard side always has a better wave....and I don't even surf starboard side. I've remedied this issue by putting a little extra weight on the surf side. It's really minimal when it's just my wife, myself and my daughter as when I've driving there's 275lbs in the drivers seat so 500lbs on the port side + my 60lb daughter isn't a large offset anyways, but again that little bit helps for some reason.
PostPosted: Thu Mar 10, 2016 8:26 pm
If you have enough weight you don't pull the surf gate out of the water at all... I always have people sitting on surf side with all ballast full.
PostPosted: Thu Mar 10, 2016 10:59 pm
And in my boat it is a noticeable difference when you are surfing.
Users browsing this forum: No registered users and 80 guests
