It is currently Fri Oct 16, 2026 8:56 pm
 Post subject: Heater
PostPosted: Sat Oct 09, 2010 11:17 am
Hey guys, I just noticed that the 2010 Vandall edition says on the axis wake website that it comes with a 2 outlet heater. My dealer never told me about the heater and also I have not noticed it at all. I just put my boat up for winter so I cannot go and check where the heater may be now so I wanted to ask you all where the heater is located, where the outlets are and also where you turn it on (I assume the on off switch is on the dash). Thanks in advance
 Post subject: Re: Heater
PostPosted: Sat Oct 09, 2010 3:32 pm
the heater and blower motor is all one unit behind the driver side kick panel in front of your feet, one outlet blows at the drivers feet and the other outlet is in the panel between the walkthrough, right by the rear flip up chillax, it has a 5ft hose that you can pull out and aim at passengers
PostPosted: Sat Oct 09, 2010 3:34 pm
you usually need to have the engine speed over 1000rpm to get it to blow hot because the water flows too slow at idle to stay warm, but when you are cruising its hottt
PostPosted: Mon Oct 11, 2010 9:00 pm
Well, after further investigation My vandall edition did not come with a heater. I called my dealer and he said they must have forgot to put it in at the factory. I had to email him pictures of the boat where the heater should be and he is going to contact someone at Axis to see what they can do.
PostPosted: Tue Oct 19, 2010 8:07 pm
hey pinto lets see some pics of your boat!!
PostPosted: Thu Oct 21, 2010 3:33 pm
Here are a couple pics.
Users browsing this forum: No registered users and 78 guests
