It is currently Thu Nov 12, 2026 10:55 am
aguaskis
Post subject: Re: wtf axis - oil change hose Posted: Thu Oct 23, 2014 6:04 am |
Joined: Wed Apr 30, 2014 5:13 pm Posts: 159 Location: BumpASS, Vagina
Ditto on the oil filter. The housing the oil filter is attached to will bend. I ended up getting a hammer and with the rubber hangle, had to pry against the frame and with an oil wrench was able to finally give it a hard quick pull and it finally broke loose. Dam, they have a rubber seal and really only need to be hand tight or just a little better. Get 'em kingranch !!!
schwarzfj
Post subject: Re: wtf axis - oil change hose Posted: Fri Oct 24, 2014 10:36 am |
| Newbie |
I to experienced the dreaded 1st oil change on a new 2014 boat. Can't believe how tight the oil filter was on. Questioned the direction I was turning the filter several times, always with the conclusion I was going the right way. Approx. 2 hours later, thankful the filter didn't crack, a little praying, I was finally able to get it to budge by applying a combination wrench to my ratchet creating a cheater bar for leverage. Unbelievable.
amsugg
Post subject: Re: wtf axis - oil change hose Posted: Wed Oct 29, 2014 7:27 am |
I always have problems with my oil filter and i don't over tighten them and i have all the tools to get them off( i work at car shop). its the stupid filter relocator bracket, that bends and kills your leverage. i always have to get the wifey to put her foot on it while i remove it to get the leverage.
hushpuff
Post subject: Re: wtf axis - oil change hose Posted: Thu Oct 30, 2014 10:16 am |
Same problem on my first oil change... my impatience led to a gouged filter housing... Need to find a machine shop to mill it down for me. I can't find a filter pedestal on its own without the kit. My drain hose also does not quite reach the drain hole, I don't even think it would fit through it due to a random bump in the fiberglass.
Grief.
markos250
Post subject: Re: wtf axis - oil change hose Posted: Wed Dec 31, 2014 6:50 pm |
| Boater |
when in doubt acetylene her out made alot of smoke lol
dezul
Post subject: Re: wtf axis - oil change hose Posted: Thu Jan 01, 2015 12:42 pm |
[attachment=-1]uploadfromtaptalk1420137711583.jpg[/attachment]
This is what I use to get the filter off. It works perfect.
| Attachments: |
boardjnky4
Post subject: Re: wtf axis - oil change hose Posted: Thu Jan 01, 2015 10:51 pm |
Go to Home Depot and you can get some adapters and attach the drain hose to a pump. Easy peasy no mess.
Users browsing this forum: No registered users and 58 guests |
