It is currently Sun Jul 06, 2025 1:00 am
 Post subject: Re: The little motor that could.... the 335
PostPosted: Sun Apr 28, 2013 8:54 pm
2315 here. Going out tomorrow. I will top the tank off before and after and get you a good number. I'm running the stock tans plus the fly high 950 under neath up front and straight line 900s in the rear. I'm gonna be playing with the wedge a bit too.
PostPosted: Mon Apr 29, 2013 8:52 am
get_sum,
Can you get top speed on the 2315 with no weight as well?
Thanks
PostPosted: Mon Apr 29, 2013 11:14 am
Quote:
I get excellent gph with wedge for how much weight I run too. Anyone have the 2315 yet? Curious how it does. Also it help gph believe it or not to run a sack in the bow and let's you run more in the back too. I run 1100s in the rear factory arrow sack under seat and a bow triangle as well all topped off. Wake is amazing and the boat gets up albeit pretty slow with the 335 and te 1235 prop. I plan on getting the 2315 tho
I'm not seeing ~4500lbs ballast with a 1235. I've got a OJ Cinco and I can't plane with a 750 in bow with arrow, full tanks and 750's in rear. I have a buddy with same setup and a 2315 and his only planes when there is about 500lb in bow.
How long to plane out? I'd like to see differences in Acme 2079 and 2315.
PostPosted: Tue Apr 30, 2013 2:07 am
I am running 1100 lbs in the bow on top of arrow sack to get it on plane... Sorry if you cannot see it. Have never timed it but it takes a while. Usually have to dump the rear bags for about 20 secs to get it up.i had the cinco prop and got rid of it because I got more low end out of the 1235. Couldn't run the 750s In the rear full with the cinco. If I had the tears full and didn't have bow sack it wouldn't plane
PostPosted: Tue Apr 30, 2013 2:11 am
Also I am pretty close to sea level maybe +400 ft maybe that is part of a diff. My boat was one of the last 2012s without cats too... I have to leave throttle pinned and I would say maybe 30 secs to get up. It's not ideal but will have to do until I get the 2315.
PostPosted: Tue Apr 30, 2013 9:16 pm
Posted elsewhere but here is a copy paste: 2315 info.... Empty top speed was a GPS calibrated 39.6 mph. I threw everything I had at it and it just pulled like a boss! I had all tanks full, both 900s in the rear full, the front "950" shroom sac full, a 400 on top of the in the front, a 750 sideways in the center floor, and the wedge down. All said and done, roughly 5k in ballast and wedge. The prop and engine did not struggle one bit!
PostPosted: Tue Apr 30, 2013 10:28 pm
Wow, that sounds very promising! Did you note the RPMs for top speed or weighted WB speed?
PostPosted: Tue Apr 30, 2013 11:36 pm
Where is the cheapest place to get this prop? Any coupon codes and oh yea perfect condition 1235 for sale now for 375$ let me know if interested! Lol
PostPosted: Wed May 01, 2013 2:50 pm
I got mine from wake props. I didn't have a code.
PostPosted: Wed Oct 02, 2013 1:59 pm
3.9 GPH on Saturday.
I put 6.1 hours on my boat at another learn to ride day. Started topped off of fuel, then afterwards filled it again, put in 23.9 gallons.
Same as all the other events, pulled a ton of riders, first timers to semi-pro's, 1000 lbs ballast to 4000 lbs, always had 8-10 people in the boat plus gear. Only difference this time was I pulled 4 surfers for almost 2 hours. All were port side (all stock ballast full, port 750 full, bow sack 1/2, most of the people over on the port side, plus my lead) wake was very good for never really surfing my boat before, and I have the old 2011 platform.
Anyhow, I was getting 3.5 gph with the 1235 and no surfing, 3.9 with the 2315 and a lot of surfing.... still really really good.
