It is currently Sun Nov 01, 2026 5:06 am
Post new topic Reply to topic  [ 25 posts ]  Go to page Previous  1, 2, 3
 Post subject: Re: Anyone have an A22 in 7ft garage?
PostPosted: Sat Feb 27, 2016 7:52 am
Don't forget it also depends on the angle of entry into the garage. downhill entry will require more clearance.
-aha-
PostPosted: Fri Mar 18, 2016 5:27 pm
I have a 2015 A22 and it fits in my garage...by a fraction of an inch. The highest point with the tower folded down is actually the center of the windshield.
PostPosted: Sun Mar 27, 2016 12:17 pm
elc wrote:
@gtoddh
you can try a drop hitch or cranking the jack all the way down and pushing the boat into the garage. this should give you a couple more inches of clearance.
The dealer brought a demo A20 to my house last week and it fit through the door! I'm not going to have to make any adjustments. I was so relieved!
My spray date was 3/24. I'm really looking forward to getting the boat and getting out on the lake!
PostPosted: Sun Apr 03, 2016 8:51 am
Well the question was answered (for me anyhow) yesterday when I got the boat home. I had 6' 10 1/2" of clearance with my garage door header and the boat went in the garage at 6'10 3/8". Literally a hair under where I needed it to be. Pushed the weather strip on the header out of the way as it went under.
High point on my set up was the chrome Bimini leg holder. In order to get the tower as low as possible I had to fold my "tower wings" out as suggested by another member so that the tower can drop to its lowest. Doing this necessitates a larger garage door opening as the wings, with the swivel racks attached, stick out an additional few feet on either side of the hull. Using this set up in a single garage door opening would be next to impossible so keep that in mind. With the tower "wings" in the tower height was raised up a few more inches and I would not have made it inside.
Hope this helps someone down the road! Cheers......
Toy Store:
2016 A22 Green/White
2009 Built Jeep Wrangler
1978 Bandit Trans-Am
PostPosted: Sun Apr 03, 2016 11:10 am
I'm happy it worked out for you!
