It is currently Thu Mar 19, 2026 2:23 pm
Post new topic Reply to topic  [ 23 posts ]  Go to page Previous  1, 2, 3
 Post subject: Re: A20 vs T22/T23
PostPosted: Sat May 06, 2017 5:51 am
r33pwrd wrote:
gibbs114 wrote:
Brian5366 wrote:
Gibbs, do you care to tell us once again what the exact setup you are running in those pics? Also do you deploy the wedge? Thanks!
I measured mine at around 23 ft to the curl.
Current Setup
All hard tanks full
1100's rear
Bow sac full under seats about 550lbs
150 lbs lead in the nose
400 lbs sac front walkway
155 lbs fat brick rear surf side
Is that what you run with a small crew?
Yes that's with 3 to 4 people
PostPosted: Thu May 11, 2017 9:46 am
I have a T23 and love the wave. I previously had an A22 and liked that wave as well but prefer my T23. I am attaching a photo and a link to a drone video I did this week of my friends riding. In the photo or at 23 seconds into the video you can see how far back she get and recovers on an Inland Surfer Air Series 134cm. She is pretty new to dropping back and recovering so there is probably a bit more room. I also think seeing the guy ride helps with some perspective too. He is about 300#'s and riding a Phase 5 Trident 60" board and an Inland Surfer G-Ride 142cm board in these shots.
As for weighting stock ballast, bow bag, 750's rear, 80# steel in the very nose, 160# far aft, and 400# of steel midship (80# behind the driver and 320# behind the batteries and in front of the batteries split evenly. I am also using the wedge.
PostPosted: Sat May 13, 2017 8:55 am
Walter17 wrote:
That's awesome AJ and really helps a lot. The point to make here is that one is able to surf roughly an additional 10' further back with the 22-23' boats. That's really where I am going with this and what guys are saying as it doesn't even come close to draw a comparison between my little A20 (which I love) and the T23/A24.
Now I just need to be able to justify a new T23 with the Supercharged 550 to the Mrs. I can sell the T23 just fine, especially with not having to trailer as much anymore, but the beef cake engine that might be a harder sell. Might have to throw in a new purse for her or something that she cares about. Cause if/when the T23 happens I will likely be doubling the ballast from what my A20 currently has, plus it is just down right fun. Drove a '15 MXZ24 with the supercharged engine last summer and the thing planed out in what seemed like a count of 1 in my head. But I am sure the new 409 motor with the right prop will do just fine since my 350 does just fine with the set up we have.
On a 14 a20 I run 850 rears (bad plumbing install fill 750-800), 950 mushroom front pnp -fill 700-800?, full wedge , stock and 3 150's in bow cushions, load yours some more or move 3 biggest adults plus more to bow and your pocket will extend, or put bow sac on top of cushions additionAl to your front pnp and you may need more prop than a 1235 to come up to surf speed, Ninja your boat and you may be surprised and save some money and not upgrade, I did love the T23 I rode at surfest but I doubt I'll be getting rid of my $50000 boat to go in debt for a better wave, yes I was not as enthusiastic about mine when I came home after surfing 10 $80000 boats or better, still keeping mine
