It is currently Mon Mar 16, 2026 3:02 am
 Post subject: Towing A22 with cover on?
PostPosted: Tue Apr 12, 2011 8:31 am
Do any of you tow your A22 with the cover on? I have only done this on secondary roads going no more than 40mph. Was wondering if the cover would stay on going 65mph.
 Post subject: Re: Towing A22 with cover on?
PostPosted: Tue Apr 12, 2011 9:16 am
Yeah we tow with the cover on all the time. I asked when we bought it and I was told it the cover was designed to be left on while towing. Towed our A22 from Denver to Lake Powell with the cover on. Routinely towed it 60+ miles to and from the lake with the cover on all last summer.
PostPosted: Tue Apr 12, 2011 3:27 pm
I've always towed mine with the cover on. Typically I just cinch the cover a bit tighter than usual to make sure that it doesn't flap and mar the gelcoat.
PostPosted: Tue Apr 12, 2011 6:28 pm
I tow with the A22 cover on all the time. I try to stay under 60 when I am towing with the cover.
PostPosted: Tue Apr 12, 2011 6:55 pm
I tow mine with the cover all the time. The cover stays put even at highway speeds.
PostPosted: Wed Apr 13, 2011 11:23 pm
I have never towed mine with the cover on, I usually keep the tower folded down to keep bug guts off the speakers, it sucks having to clean it before it gets in the water, that and my last boat I towed with the cover shredded it going down the road. Also I'm minimum 125 miles from any water
PostPosted: Fri Apr 15, 2011 7:05 am
Thanks for the info guys. That will def. save some time not having to remove the cover every time I move the boat.
