 Post subject: Changing the transmission and V-drive oil
PostPosted: Wed Jun 05, 2013 5:26 pm
Has anyone done it, or know how? I looked around and didn't see a drain plug for either.
 Post subject: Re: Changing the transmission and V-drive oil
PostPosted: Wed Jun 05, 2013 6:36 pm
Do you have a documentation package for your boat? The Indmar manual will cover the process - http://www.indmar.com/service-support/manuals.aspx and you may have a specific transmission manual. Do you know which transmission you have? If not, post a pic and we can identify it for you.
viewtopic.php?f=14&t=259
This is the Ski-Vee transmission - http://www.themalibucrew.com/forums/ind ... nsmission/
The manuals will have a fill capacity for the tranmission but you should always check the fluid level rather than just adding the "correct" amount. An oil pump is also a big help to extract the fluid.
PostPosted: Thu Jun 06, 2013 5:22 pm
You should use a suction pump like the one used for changing the engine oil, just do it through the dipstick hole, they hold around a quart each but always put it in the water and double check both after running for a few minutes
