It is currently Fri Jul 03, 2026 6:42 am
 Post subject: Need Audio Help
PostPosted: Wed Jul 24, 2013 3:08 pm
Just picked my new 2013 a22 up yesterday and need some help. I have one tower speaker that is not working. I am not an audio guy but I switched it with another, thus eliminating a bad speaker because I had the same problem. After that I ended up bridging the non working speaker and did get it working. Does this mean my amp has a bad port? Again not an audio guy but hoping my terminology is correct. Another problem I have discovered is that my transom remote is not working. Checked both ends and they are plugged in, but noticed on the back of the remote it seems to have 2 sets of wires, one plugged in correctly and the other seems to have been purposely cut off. Is this correct? Any help from you audio guys would be greatly appreciated. Yes the boat is under warranty but I am not wanting to have sit at the dealer waiting on parts or something right now. I haven't even had it in the water yet.
 Post subject: Re: Need Audio Help
PostPosted: Thu Jul 25, 2013 11:42 am
when I got mine the dealer used crapy RCA wires. I replaced them with a good set and since then I have had no issues
PostPosted: Thu Jul 25, 2013 4:14 pm
Grab a Mini jack (Male)-to RCA (Males)
disconnect the rca's from head unit connecting to amp. plug rca's from phone into amp. See if the problem continues. If it doesn't it could be bad RCA's or problem with head unit.
