It is currently Thu Oct 15, 2026 3:49 am
Post new topic Reply to topic  [ 32 posts ]  Go to page 1, 2, 3, 4  Next
 Post subject: Axis Surf Gate Measurements - 2014 Axis A22
PostPosted: Sat Oct 12, 2013 9:22 am
Attached are the measurements for my surfgate. All the measurements are in inches. I don't know how to get the angles. I don't have the tool required for angel measurement. Any suggestions?
 Post subject: Re: Axis Surf Gate Measurements - 2014 Axis A22
PostPosted: Sat Oct 12, 2013 4:43 pm
Thanks Dezul! If you or anyone else can take a pic with camera positioned directly in the center of surfgate and level/square (size or cropping does not matter) I can turn the pic into a template.
PostPosted: Sat Oct 12, 2013 6:50 pm
Will do tomorrow.
PostPosted: Sun Oct 13, 2013 7:26 am
Negative
PostPosted: Sun Oct 13, 2013 7:27 am
Starboard
PostPosted: Sun Oct 13, 2013 7:30 am
It is difficult to get a good one of the portside because of light. I will take another pic later today.
PostPosted: Sun Oct 13, 2013 8:18 am
Thanks! That will work just fine. Later today Ill; transfer the measurements, cleanup the image , and scale it to actual size to make a good template. Since most folks dont have a large format printer, Ill split is up across 4 pages and add alignment dots.
PostPosted: Sun Oct 13, 2013 9:41 am
Cool deal.
PostPosted: Sun Oct 13, 2013 2:30 pm
PDF template File: https://dl.dropboxusercontent.com/u/764 ... rfgate.pdf
You should be able to print using Adobe Reader X, which you can download from Adobe’s site here: http://get.adobe.com/reader/
Open the PDF, and select Print, then set the following options under "POSTER" button options:
Page Scaling: Tile Large Pages
Tile Scale: 100%
%Overlap: 0.5 in
Make sure to setup your printer to use the largest paper size you’ve got available, there will be less pieces to put together that way.
Tape it together, cut out the middle, and trace it on to a 3/4" piece of HDPE plastic. Min material you will need is two 14" x 20" pieces.
PostPosted: Sun Oct 13, 2013 6:15 pm
Sweet. I have a couple of buddies with the 2013 a22. They will love this template. Thanks. If anyone needs anymore pics of the '14 let me know. I can usually get them the day of considering my boat is parked next to my house.
