It is currently Sun Jul 06, 2025 7:32 pm
 Post subject: New Sumo bags 1 inch fitting don't work
PostPosted: Fri Apr 25, 2014 7:09 pm
Got my new Sumo bags and the quick connect fitting get don't work. Some of the fittings are to small. So I'm a little worried about the rest of that seamed to work. It's like they are just a little too small the treads will just grab if you put any pressure on it they will fall out. I got all but one and that one I put marine adhesive and letting it dry over night. I hope it works or I'm going to be hacked off. Want to go out this weekend.
2013 A22
 Post subject: Re: New Sumo bags 1 inch fitting don't work
PostPosted: Fri Apr 25, 2014 9:11 pm
Your ordered the wrong fittings. Return them.
PostPosted: Fri Apr 25, 2014 9:25 pm
There is a big difference from the 1" fittings and the 3/4" fittings. Not all the bags from SL have the new valves. You will need the rings on the bags that are not holding. I have already sent SL an email to get you some rings for these bags.
PostPosted: Fri Apr 25, 2014 9:32 pm
The arrow bag seams fine. It's the back bags. And the rings on the bags seam to be to big but not all of them. The ones that thread in seem to be OK. It would of been nice to know when I ordered them that this was a problem or could be a problem. I also thought these were the new bags with all the issues that I've read about were fixed. And by the way they say to be 1 inch fittings.
2013 A22
PostPosted: Fri Apr 25, 2014 10:08 pm
We just found out after we received the bags that not all sumo bags have the new valves. I have already sent in an email about your bags and we will get something done for you. We ordered bags again because we were told that the valves were updated.
PostPosted: Sat Apr 26, 2014 5:17 am
Thanks, I know it's not your fault.
2013 A22
