It is currently Tue Nov 17, 2026 2:06 am
 Post subject: How to "auto volume"
PostPosted: Sun May 18, 2014 7:42 am
I know how to toggle this on an off. What I cannot seem to figure out is how to get it to work. I assume once set I leave my volume and it increases as I speed up?
Or do I set my max volume and it will decrease when I slow down? Messed with this thing for two days and I'm starting to think it doesn't actually work.
 Post subject: Re: How to "auto volume"
PostPosted: Sun May 18, 2014 8:35 am
It only goes up a little bit, it's pretty much worthless. Same on the malibus.
PostPosted: Sun May 18, 2014 10:01 am
Am I correct in the assumption that I set the volume at a standstill?
Anyone know what speed it takes to get it to increase?
PostPosted: Sun May 18, 2014 10:05 am
Mine increases as soon as I give it any throttle I can here it go up as I slowly throttle to 5mph, but it's such a small increase any faster and you can't here it at all.
PostPosted: Sun May 18, 2014 10:13 am
Guess I had the opposite problem, my auto volume is way too loud. Even around the dock if I bump the throttle a little it's increases louder than I need
PostPosted: Sun May 18, 2014 10:54 am
Through the settings menu on the gauges.
PostPosted: Sun May 18, 2014 12:27 pm
I have mine on max and it will only raise the volume 4 numbers
PostPosted: Mon May 19, 2014 11:42 am
only time I have problems is when my hand gets a cramp .... lol
PostPosted: Mon May 19, 2014 9:06 pm
damn.....not that its difficult to raise and lower the volume, but would be badass to be able to set it and forget it!
i have wetsounds amps, speakers, etc...but putting around im about 20 on the sony head unit, and when pulling a rider around 40.
PostPosted: Mon Jun 09, 2014 11:10 am
So no real answers here. Can anyone really explain this. How is works? How it is wired to the head stereo unit?
I know how to turn it on through the main gages too but mine is like everyone else here. I can't tell if it actually does anything on any setting.
Are there any Axis techs on this site?
This looks like an issue that should be able to be easily explained.
Is there something else that has to be turned on on the head unit to pair the two?
Please help!!!!
