It is currently Sun Oct 18, 2026 7:41 am
[ 3 posts ] |
Gibster786
Post subject: Another winterization Posted: Wed Nov 02, 2011 8:37 am |
Joined: Wed Sep 14, 2011 2:15 pm Posts: 165 Location: Virginia Beach, Virginia
I have searched the malibu forums for a good write up on winterization. Can one of you guys that are a member over there help me out.
I dont know if my other post was read but do any of you recommend shrink wrapping the boat for the winter?
Also I need to goo info on how to winterize ballast tanks in our boats.
_________________ Gibby 2011 A22 Vandall
rpinto
Post subject: Re: Another winterization Posted: Wed Nov 02, 2011 1:09 pm |
| Axis Owner |
I just finished up winterizing my A22 last weekend. I can't advise you on Shrink wrapping your boat as mine is stored in a barn but sounds like it wouldn't hurt to do. For the ballast I just made sure the hard tanks and lines are empty and also removed all of the plug and play bags from the boat.
Armada
Post subject: Re: Another winterization Posted: Wed Nov 02, 2011 6:35 pm |
For the shrink: does for boat will be inside if so what will be the temp?, or outside protected? For the ballast: you need to put antifreeze in the ballast and run the pumps tp make sure there antifreeze in the system. The easiest way to add antifreeze I found is to put it directly in the lines at the back of the boat in the engine compartment.
[ 3 posts ] |
Users browsing this forum: Google [Bot] and 36 guests |
