It is currently Mon Jul 07, 2025 3:54 pm
 Post subject: T22 surf set up?
PostPosted: Sun Jan 11, 2015 7:10 pm
:shock: Need suggestions on setting up my new T22 for surfing?
Thx in advance
 Post subject: Re: T22 surf set up?
PostPosted: Mon Jan 12, 2015 8:35 am
I run 750s in the rear and the bow sack (unsure of the size) full as well as all hard tanks. Wedge down we found to be better push. And around 10.6 to 11mph depending on rider. Hope this helps. Btw I have 330hp and 2419 prop.
14 t22 with sg
PostPosted: Mon Jan 12, 2015 7:19 pm
What RPMs are you running with that setup? How big is your crew on a typical day?
2018 T22
PostPosted: Tue Jan 13, 2015 12:29 am
Around 3000 rpm and we usually have anywhere from 3 to 12 ppl we are at about 1700 feet elevation.
14 t22 with sg
PostPosted: Tue Jan 13, 2015 11:00 am
AtxRyder what year T22 and what motor/prop setup?
PostPosted: Sat Jan 31, 2015 6:05 pm
I have the 350hp with the high altitude prop. What sacks exactly do I need? Do i fill both sides up full?
PostPosted: Tue Feb 03, 2015 5:26 pm
AtxRyder
Here are two links with pictures to the way we setup our 2014 T22 and our 2015 T22.
2014 T22
Ballast: Stock Full, 900lb Sumos in the rear, Sumo triangle bow under the seats (550lbs or so), 400lbs on top of the seats, wedge was deployed for surf and retraced for skim
2015 T22 weighted the same as my first post in this thread.
900lbs - Stock hard tanks
2850lbs - PnP - Sumo 900lbs in the rear lockers (1800lbs) and an 1100lb* sac on the bow seats.
800lbs of people weight
Wedge deployed with surfgate
11.5-12mph depending on the rider preference.
Starboard -
Port -
PostPosted: Wed Feb 04, 2015 11:37 am
ATX you should call your buddy in Austin, TX and talk to him. He can probably help you out. :)
PostPosted: Wed Feb 04, 2015 11:54 am
I know a guy
Users browsing this forum: Google Adsense [Bot] and 59 guests
