It is currently Mon Jul 07, 2025 3:52 am
 Post subject: front hard tank won't drain
PostPosted: Sun May 24, 2015 7:37 pm
Hey guys 3rd Time out with the new A22. I noticed that the bow was heavy when I launched, also was sitting a little low. We were still getting to know the boat, I put 750's in the rear 2wks ago. Well I was draining everything and I noticed the front was not draining. Flipped it to fill just to check if it wqs full and it was overflowing out the vent. Wont drain. I am going to talk to the dealer tuesday, but what do you all think could be the problem?
 Post subject: Re: front hard tank won't drain
PostPosted: Sun May 24, 2015 7:38 pm
Hard tank or front bag?
PostPosted: Sun May 24, 2015 7:39 pm
Never mind I read your title.
My front bag had the check valve in backwards when I took delivery.
PostPosted: Sun May 24, 2015 7:45 pm
Yeah hard tank. I have a 950 bow sack to put in ...but I have to figure this out first...
PostPosted: Mon May 25, 2015 7:48 pm
A little more info...the circuit breakers are not tripped. With it back in storage, I flipped it to fill just to see if it turned on, it did... turned to drain , nothing at first. Then listening intently I heard a faint hum. I then did the same with the center tank (which drained), heard the same faint hum when flipping it to drain. Well I will call the dealer tomorrow.
PostPosted: Mon May 25, 2015 10:14 pm
The A22 doesn't have a front hard tank. The front pump is only for the the plug n play hoses to hook up a bag.
It sounds like your front fill hose is hooked up to the vent hose so it just over flows when you flip the switch.
PostPosted: Tue May 26, 2015 5:18 am
Thanks for the info Wilbur! just searched online and found that you are correct. the hard tanks in the rear hold 250 lbs each and the center holds 400 lbs. I guess I will have to get the front sack hooked up I have the 950.
PostPosted: Tue May 26, 2015 11:58 am
There also isn't enough room under the front seats for the 950lb bow sac to fill all the way.
I have the 500lb Sumo bow sac and I'm not even sure if that fills all the way to 500lbs
PostPosted: Tue May 26, 2015 7:32 pm
Well I have the 950 bought and paid for...so I will give it a shot. I was wondering about that but that was the size the dealer recommended. They also recommended 400's for the rear.. figured that was the lawyers recommendation
Users browsing this forum: No registered users and 62 guests
