It is currently Sun Jul 06, 2025 5:16 pm
 Post subject: Planning to order boat, Questions
PostPosted: Tue Aug 18, 2015 3:36 pm
I have a few questions, still deciding on what boat I want, but as of right now I am leaning towards a T22. Would appreciate answers or advice on any of these
I was originally planning on going with the autoset wedge, but see that many people go with the manual, could someone explain why you would chose one over the other? What is the cost difference?
When I priced out an A22 I noticed there was a charge for the black base gelcoat color, is white free? I know it is on Moombas.
Does deckadance just lay on the floor or does it snap in?
Do these boats come from the factory with rear and front sacs?
Can I get a 2313 or 2315 prop installed from the factory?
Do the trailers come standard with brakes? Torsion or leaf sprung axles?
I am thinking about going with sound pack 1 and putting exile speakers in the tower, is it a major pain to get wiring through the tower?
Thanks
 Post subject: Re: Planning to order boat, Questions
PostPosted: Tue Aug 18, 2015 3:37 pm
One more, the 2016 boats come with a 5 year engine warranty correct?
PostPosted: Tue Aug 18, 2015 3:58 pm
Ill answer the ones I Know..
-Come with stock hard tanks but PNP is additional
-Trailer comes standard with Torsion and brakes
-Tower is wired for speakers (I had sound pack one and added the front bow speakers and 4 exile towers with the 5 and 2 channel amp) Call Bakes Marine for your exile gear!
On a side not Exile has the best customer service of just about any company I have every worked with! I would buy their gear any day!
PostPosted: Tue Aug 18, 2015 4:03 pm
Is the plug and play just the plumbing, or does that include sacs too? Which size if it does?
Did you have the bow speakers added to sp1 from the factory or did you add them yourself?
Thanks!
PostPosted: Tue Aug 18, 2015 4:35 pm
Plug and play does not come with the ballast bags. You should be able to work them into the deal. Just ask your dealer. The torque prop option for 2015 was the 2313, not sure what prop options are being offered for the '16s. White gel coat doesn't have an up charge (straight up or flip side), but solid color hulls and metal flake will be extra.
PostPosted: Tue Aug 18, 2015 5:53 pm
Auto set wedge, is manual. The "auto" refers to it setting itself to the correct position automatically once its manually deployed.
PostPosted: Tue Aug 18, 2015 6:16 pm
Thanks!
I added them.. took about 15 minutes. Only comes with plumbing not bags.
PostPosted: Thu Aug 20, 2015 9:42 am
Thanks guys, appreciate the knowledge.
Looks to me like deckadence just lays down based on a video I watched.
Can anyone confirm 5 year engine warranty for 2016?
Also can anyone give me pro and cons of the auto set vs manual wedge? What would you do?
PostPosted: Thu Aug 20, 2015 9:49 am
Another question, surf pipe. Is it a yay or a nay? Better to go with aftermarket FAE?
PostPosted: Thu Aug 20, 2015 10:36 am
Read SDUKES reply, he already answered your question about the wedge
