It is currently Sun Jul 06, 2025 6:24 am
 Post subject: trade my 2249 for your 2315?
PostPosted: Mon Feb 22, 2016 4:08 pm
Anyone
 Post subject: Re: trade my 2249 for your 2315?
PostPosted: Mon Feb 22, 2016 4:38 pm
I just got the OJ945 for this year it will be very close in performance to the 2315. You might give it a look also.
PostPosted: Mon Feb 22, 2016 4:47 pm
Might want to keep the 2419 in mind as well since it's more aggressive than the 2315 if you are wanting max wakeboard ballast with the L96 motor (I have the same motor). However, 2315 is a great all around prop. I'd actually like to try one for my uses which is 90% surf.
PostPosted: Mon Feb 22, 2016 5:51 pm
so you are running the 2419 right now? to many options I tell you :)
Ideally I would like a one does all prop for both surfing and wake boarding but we surf 90 percent of the time as well and the 2249 does pretty well but anything over surf speed it fights hard.
PostPosted: Mon Feb 22, 2016 6:32 pm
I ordered my boat with the 2419 knowing I would be using 4600-5400lbs of surf ballast. I also knew it would have a decent top speed of 38-39mph. I can plane with 4500lbs to wakeboard if needed but I don't ever fill that heavy except for giggles, plus it takes a little time to plane that heavy. Im more 3000-3250lbs plus wedge.
PostPosted: Mon Feb 22, 2016 6:49 pm
Okay anyone have a 2419 they want to trade or want to buy a 2249 :)
PostPosted: Mon Feb 22, 2016 7:16 pm
I'm at 550' above sea level as well
PostPosted: Mon Feb 22, 2016 8:49 pm
I saw a 2315 for sale on TMC
