It is currently Sat Jul 05, 2025 9:29 am
 Post subject: For those running the T-Series bow bag.
PostPosted: Mon Mar 21, 2016 8:48 pm
So I'm running the T-Series P&P triangle bow bag in my 16 A20, I notice that when we are wakeboarding water is coming out of the the through hole fitting that the bag drain line is hooked to. Obviously with the bow up a bit the water is pushing through the drain pump and out the through hole. Is this happening to anyone else? Thoughts?
 Post subject: Re: For those running the T-Series bow bag.
PostPosted: Thu May 26, 2016 7:30 am
I think that happens on our T23, it's just overflowing out of the bag. No biggie
2015 T23, 350, High Altitude prop, FlyHigh front/rear pnp
PostPosted: Thu May 26, 2016 8:43 am
same happens on my 13
PostPosted: Sat May 28, 2016 8:34 am
Same here. It's annoying, so I will be installing an in-line ball valve on the drain line in the next week or so.
-aha-
PostPosted: Sat May 28, 2016 11:01 am
Happens more on my rear bags then my bow bag. Annoys the crap out of me when I'm surfing and I'm seeing my ballast pissing out the side.
2015 T23 - Sold
2018 ???
PostPosted: Mon May 30, 2016 8:52 am
There's an easy and cheap solution for bags draining out the vent... you can search the forum for my pics on the subject. I stick a rubber cork in the through hull... problem solved.
-aha-
PostPosted: Mon May 30, 2016 10:16 am
I added a wakemakers 1 way flapper check valve on the discharge line off the drain pump just before the through hole, worked great. The pressure of the pump pushes past the flap fine but the gravity pressure isn't enough to push it open.
Users browsing this forum: Google Adsense [Bot], Majestic-12 [Bot] and 52 guests
