It is currently Sat Jul 05, 2025 3:53 am
 Post subject: Adjust wedge
PostPosted: Wed Aug 03, 2016 5:55 am
Has anybody drilled a couple different holes so you could lock the wedge in different spots?
 Post subject: Re: Adjust wedge
PostPosted: Wed Aug 03, 2016 7:59 am
Reason being?
PostPosted: Wed Aug 03, 2016 8:42 am
I would probably fabricate up an adjust washer to attach to the bolt that stops the wedge when it was down before I went through the efforts of drilling holes in the bracket.
PostPosted: Wed Aug 03, 2016 9:36 am
chaser720 wrote:
Reason being?
To make it more like the Malibu power wedge, I've thought about doing this too, but I rarely use the wedge unless I have a bunch of extra fuel I want to burn up!
PostPosted: Wed Aug 03, 2016 10:24 am
I never would run a floating wedge. I would only use a wedge if it were powered and then I would always use very little. Just enough to cleanup the wake.
PostPosted: Wed Aug 03, 2016 10:41 am
Keep in mind that the floating wedge dies not float, but sits solidly against the bolt at all speeds. Someone put some nice videos proving this last year.
PostPosted: Wed Aug 03, 2016 10:54 am
Last season I never used the wedge for surfing. This season a have an extra 400# bag on the bow seats and the surf wave with the wedge is better than without.
PostPosted: Thu Aug 04, 2016 3:46 am
Regular or goofy side? Or both?
PostPosted: Thu Aug 04, 2016 6:59 am
I'd like to see that, suggestion on what to search for?
________
PostPosted: Thu Aug 04, 2016 7:13 am
Ask and you shall receive. See the link below.
viewtopic.php?f=14&t=2418&start=30
Users browsing this forum: No registered users and 120 guests
