It is currently Thu Mar 19, 2026 12:52 pm
 Post subject: HELP!!! NO ECM DATA
PostPosted: Sat May 27, 2017 6:52 am
Checking my boat over after it was dewinterized and noticed only one battery has enough juice to power the boat. Odd considering the voltage was just checked by the dealer. So now I'm down to one battery and I notice my display reading NO ECM DATA. Radio is acting a little funny as well, like the amps aren't getting enough power. I'm about to haul the boat and a boat load of kids 2+ hours to the lake and I'd like to know if I have a problem then how to fix it. Original batteries, 2014 A22 VE w/350
A22 2014
 Post subject: Re: HELP!!! NO ECM DATA
PostPosted: Sat May 27, 2017 8:27 am
Probably have a dead cell, they can pass voltage test with no load but fail under load, if you have a meter test it with the switch off then switch it on and key on radio on etc and let us know the voltage then.
PostPosted: Sat May 27, 2017 10:48 am
Or the Kill switch under drivers console
PostPosted: Tue May 30, 2017 6:13 am
Once on the water, the boat fired up with the use of both batteries. I ran it for the next 20 minutes to charge them up. Electronics are back to functioning normally. I may have reached the limit on my pair of batteries, after all they're four years old now.
A22 2014
