It is currently Sun Aug 30, 2026 1:47 am
 Post subject: Fuses
PostPosted: Thu Jul 12, 2018 3:19 pm
I have a 2012 Axis A22 and the front ballast fuse underneath the throttle trips every time I try to fill the tank. Question 1: is the fuse located within the button itself? Question 2: What amp do I use to replace it?
2012 A22 Black Vandall Edition
 Post subject: Re: Fuses
PostPosted: Tue Jul 17, 2018 12:49 pm
Those are reset-able fuses not replaceable. You have a bad ballast pump.
PostPosted: Tue Jan 15, 2019 2:11 pm
Possibly sand silt I the pump also. Reason mine was tripping at one point. Had Backflow issues through the pumps also while surfing that we finally got fixed at 3 trips to the shop.
2017 Axis T23 Red/Charcol, dual axle trailer, heater, chilax seating, flipping captains seat, sound pack 2, surfgate, and wedge. 850 sumos rear 675 bow
