It is currently Thu Mar 19, 2026 3:33 am
 Post subject: Nav Lights when anchored
PostPosted: Fri Jul 20, 2018 9:02 am
I have read the manual and did not see anything on this. We have a '17 A20 and on the 4th we went to watch fireworks. With the engine off, how do you turn the anchor light on? I turned the key to the ACC position (back) and they would not operate. I had to turn the key to the position where the blower comes on to get the lights to come on.
Is this the only way to get the lights on or is my boat wired incorrectly?
 Post subject: Re: Nav Lights when anchored
PostPosted: Fri Jul 20, 2018 9:04 am
That's how they work.
PostPosted: Sun Jul 22, 2018 8:23 pm
Sadly I struggled with that same issue on the 4th.... My prior boats could run the lights in acc, guess it's just how they work on the axis
First Boat - Tiny AlumaCraft w/ 8hp Johnson
---- Nothing -----
Last Boat - 2016 Four Winns H180RS --- RIP 1/25/2018
New Boat - 2018 Axis T22!!!!!!!!!!!!!!!
PostPosted: Mon Jul 23, 2018 5:30 pm
So this is what screens vs switches gets you, lights used to be a switch for anchor and nav , nav in the up position, neutral position for nothing”, anchor in the down position and independent of the key switch for a safety reason or am I crazy, no way you want an anchor light that takes a key switch
It should be just like an accessory switch
