It is currently Tue Mar 17, 2026 4:56 am
 Post subject: What is the weight of the stock ballast - T22?
PostPosted: Fri Aug 03, 2018 10:19 am
I had a number in my head, but I can't find it - not in the manual, not in the booklets, not on the website.
Best I found was in 2014 someone said the rear's were 200's that only weighed 180 when removed & filled. I was told the center ballast was 500 or 600, I was also told the 200's were replaced by larger ones at some point since then as well.
The marketing flyer says Triple Hard Ballast represents 800-1200lbs depending on model (no specifics by model are provided).
First Boat - Tiny AlumaCraft w/ 8hp Johnson
---- Nothing -----
Last Boat - 2016 Four Winns H180RS --- RIP 1/25/2018
New Boat - 2018 Axis T22!!!!!!!!!!!!!!!
 Post subject: Re: What is the weight of the stock ballast - T22?
PostPosted: Fri Aug 03, 2018 10:53 am
What year are you looking for? It was 900 up to 2017, 2018 went to 1100, 300lb rear tanks, 500 belly tank.
PostPosted: Fri Aug 03, 2018 12:33 pm
I was looking for 2018. Where did you find the information?
---- Nothing -----
PostPosted: Fri Aug 03, 2018 1:14 pm
Straight from Malibu engineer
PostPosted: Fri Aug 03, 2018 7:40 pm
Thanks still crazy they don't list it anywhere
---- Nothing -----
