It is currently Fri Oct 16, 2026 12:52 pm
 Post subject: Axis dash turning off
PostPosted: Sat May 02, 2020 3:15 pm
Hey guys. I have a 2012 A22 with 760 hours and just recently it has started giving me some troubles I can’t seems to figure out. I have tried calling dealers and local dealers and they aren’t much help right now. The dash will just shut off and reset in the middle of a set. The boat runs fine unless you have the cruise control set, in that case it settles back down to an idle. I have had the alternator rebuilt and checked all the grounds I can find to ensure they are clean and tight. Sometimes it is continuous and sometimes it is only one and done for the day and it works fine after that. Not really wanting to replace the gauge, I was wondering if anyone has had a similar problem or just knows more than I do about this. Thanks for the help! If the video doesn’t work let me know and I will try to post it somewhere else and link to it.
https://youtu.be/-Pae3XbUawg
Sink Responsibly
Users browsing this forum: No registered users and 83 guests
