It is currently Sat Aug 29, 2026 12:42 am
 Post subject: Help Remove Axis T23 Bow Cushions
PostPosted: Thu Apr 28, 2022 10:10 pm
Hello! I have a 2016 T23. I'm wanting to remove the front vertical bow cushion to hide some 50lb bags of lead in the tip of the bow. I've looked all over the inside of the bow and can't see or feel and mounting hardware. How do you remove that cushion?! Thanks!!
 Post subject: Re: Help Remove Axis T23 Bow Cushions
PostPosted: Wed May 25, 2022 7:39 am
Update: To remove the cushion it just pops out. It is held in place with clips like one that hold a door panel on a car. Unfortunately the hole is super small and I could barley get my arm through it to add bags into the nose of the hull. With my wife's help I was able to get 150lb of lead in the nose. It helped with the surf wave.
PostPosted: Tue Jun 28, 2022 2:57 pm
You do have a PnP bag in the front also? But an additional 300-400lbs never hurts in the bow.
