It is currently Sat Aug 29, 2026 10:51 pm
 Post subject: 2015 Axis T22 factory ballast understanding
PostPosted: Sun Jun 19, 2022 10:36 am
Hello all, I have a new to me 15’ T22. Has factory ballast with plug and play in the rear lockers and under front bow cushion with 1” hoses. I got some bags for the rears from a boating buddy and they fill as they should. I just need to understand for sure if my boat has a factory bow tank or not? It appears they didn’t come with a factory hard bow tank, just the switch on the dash and pumps and plug and play ready for the bag? If I turn the bow switch on I can hear the pump but nothing ever fills as it never comes out the side. Or if I drain it nothing comes out the side.
The Axis manual for a 15’, at least when it comes to ballast is about worthless. No info on capacity etc.
Thanks for any help on this!
 Post subject: Re: 2015 Axis T22 factory ballast understanding
PostPosted: Tue Jun 28, 2022 2:56 pm
You should have an open space in the nose of the boat for an extra bag. If you add rears you need to add bow bags or your wake will be really short. You will have a really small pocket to surf.
