It is currently Fri Mar 13, 2026 1:39 am
 Post subject: Re: DIY tricked out trailer?
PostPosted: Fri Apr 13, 2012 10:41 am
Mines an a20 on tandem tricked out. Maybe I'm confused at your question??
PostPosted: Fri Apr 13, 2012 12:20 pm
That's what I was after....thanks! I didn't know if the A20 was only intended for use on the single axle or what.
2011 A20
PostPosted: Mon May 21, 2012 1:05 pm
I just ordered and was told this is the correct offset/size for the tricked out
18 x 9 Bolt Pattern 5x4.50 Metric 5x114.30 -0 Offset
PostPosted: Sat May 26, 2012 11:57 am
I just picked up some after market 14 inch black rims for this website for $370. I think they will look good on my standard white trailer. Not bad for $370. I will post pictures when my boat arrives and have the rims installed. I am going to put the standard tires that come with the trailer on the rims. Let me know what you guys think.
http://www.trailer-wheels.com/14-x-55-V ... p_957.html
PostPosted: Sat May 26, 2012 12:04 pm
Those look exactly like some of the wheels they use on the Supra's.
PostPosted: Sat May 26, 2012 1:52 pm
Yes, that is the exact rim. I like the way they look. I have seen pictures of the rims but not on a white wakeboard boat trailer. Not a bad upgrade on the standard trailer for $370, and that's with free shipping. I think they will look good. Thanks for the pic.
PostPosted: Sat Jul 11, 2015 5:24 pm
Thanks for the info. I purchased this wheel to add the Rockstar spare to the tricked out trailer. It has two bolt patterns drilled but has the correct 5 lug pattern and backspacing. The tire needed is a 255/45/18.
XD-Series Rockstar XD-Series775 Matte Black Wheel (18x9"/5x114.3mm) https://www.amazon.com/dp/B0025KUZ6W/re ... Ovb7RZPTS6
