It is currently Fri May 01, 2026 5:04 am
 Post subject: Optima 3 battery install & 120 amp Alternator upgrade, charg
PostPosted: Sat Mar 22, 2014 11:45 am
Installed the 3 batteries, an ACR & 2 remote switches to control it all.
Mex180
2011 Axis A-20 335ss
 Post subject: Re: Optima 3 battery install & 120 amp Alternator upgrade, c
PostPosted: Sat Mar 22, 2014 12:03 pm
Are you a wakeboarder or a partier? Nice looking install but I haven't found a need for that much juice yet.
PostPosted: Sat Mar 22, 2014 12:04 pm
What speakers are you torturing with that juice?
PostPosted: Sat Mar 22, 2014 2:47 pm
You don't have to be a "partier" to want/need batteries. Three Optimas isn't a lot of amp hours to begin with for a "party" set up but it is a good choice for reliable power with a small footprint in the storage area. 3 battery set ups are the norm. Two Optimas are a little over 100 amp hours for a stereo bank (I believe they also have a 75 amp hour battery) so I wouldn't say he has a lot of "juice". Bang for the buck, amp hours, and two batteries would be two 6 volts. That would be juice at 450-500 amp hours in only 2 batteries.
PostPosted: Sat Mar 22, 2014 2:56 pm
Are you using an onboard charger as well?
PostPosted: Sat Mar 22, 2014 3:14 pm
Ride or die.....jk. my opinion will change when he post his system. He is running top quality under the helm.
PostPosted: Sat Mar 22, 2014 4:28 pm
Nicely done!
PostPosted: Sat Mar 22, 2014 9:19 pm
Anxious to see as well. W7 under helm maybe? SD6 is perfect for 3 some on the tower, but what the hell are the other 2 SD6s powering!?!? We need pics!! :D
