It is currently Fri Oct 16, 2026 5:20 am
[ 5 posts ] |
alexandera
Post subject: 2012 Toggle Switch Posted: Sun Oct 13, 2013 7:47 am |
Joined: Sun Sep 16, 2012 8:55 am Posts: 375 Location: Central Texas
Anyone know how our toggle switches are installed in the dash? Need to take the dual throw switch out for some splicing and I thought they just popped out toward the front?
_________________ -aha-
mikeakatex5
Post subject: Re: 2012 Toggle Switch Posted: Sat Oct 19, 2013 3:42 pm |
| Newbie |
I also need to know this, and to add to it how do you wire into the 2 way switches? Does someone have a diagram?
bmxcinci
Post subject: Re: 2012 Toggle Switch Posted: Sat Oct 19, 2013 5:52 pm |
| Newbie |
There are clips on the top and bottom that hold them in from behind. If you have a smooth pick or screwdriver you should be able to pry the switch out, and then press the clip down with the pick allowing. You have to do it for the top and bottom of the switch. Or you can get to if from behind. Going by memory, but I think that is correct. Just don't force it.
_________________ 2012 Axis A20
Axis_UK
Post subject: Re: 2012 Toggle Switch Posted: Sun Oct 20, 2013 11:20 am |
alexandera
Post subject: Re: 2012 Toggle Switch Posted: Mon Oct 21, 2013 11:53 am |
Here's how the two way switch works Mike.
Looking at the switch from the front view you have two columns of male connections; port side has 4/starboard has 3... unless you are using a piece of equipment that needs reverse polarity's (i.e. reversable pump) you will not use the Starboard Column (3).
Portside Diagram... top to bottom:
1 - (- ground) 2 - (+ accessory) on when switch is pushed downward 3 - (+ BATT) 12v hot 4 - (+ accessory) on when switch is pushed upward
I am getting 14v @ 20 amps out of this switch.
Hope this helps.
[ 5 posts ] |
Users browsing this forum: No registered users and 19 guests |
