It is currently Sat Oct 17, 2026 2:49 am
Post new topic Reply to topic  [ 29 posts ]  Go to page 1, 2, 3  Next
 Post subject: Homemade delta wakeshaper
PostPosted: Tue May 17, 2016 7:54 pm
Made a homemade delta. I hope to try it out this weekend. Let me know what you think.
 Post subject: Re: Homemade delta wakeshaper
PostPosted: Tue May 17, 2016 11:46 pm
I'm thinking of doing the same. Is that one of the aluminum dent pullers from ebay?
PostPosted: Wed May 18, 2016 4:44 am
It's plastic, but yes.
PostPosted: Wed May 18, 2016 9:42 pm
I found some at Harbor Freight for $8. Also found this thread last night - http://www.mastercraft.com/teamtalk/sho ... hp?t=70442. Lots of options and ideas starting about halfway through the thread.
PostPosted: Wed Jun 22, 2016 11:05 am
Did you use 1/2" or 3/4" HDPE?
Thanks
Captn Pete
PostPosted: Wed Jun 22, 2016 12:28 pm
I used 3/4 cause that's what I had. Also the harbor freight suction cup is the way to go. The HOD Amazon is not strong enough
PostPosted: Wed Jun 22, 2016 2:30 pm
So you think 1/2" would work?
PostPosted: Wed Jun 22, 2016 2:47 pm
I do, yes.
PostPosted: Thu Jun 23, 2016 12:58 am
Nice work,looks professional.
Sent from my HTC Desire 526G dual sim using Tapatalk
PostPosted: Mon Jun 27, 2016 10:24 pm
To add some info to the thread... The amazon plastic cups fell off every 5 minutes for me. The amazon metal ones worked like a charm https://www.amazon.com/COSMOS-Aluminum- ... uction+cup
Used 1/2" HDPE off amazon. Two shelf brackets from lowes, http://www.lowes.com/pd/Style-Selection ... et/3455946 . The shelf brackets have holes predrilled and they line up with the middle of the suction cups (close).
TeamTalk has an extended thread on this. I cut my hdpe 9"x6" and rounded the outer part. The entire build process took about 45 minutes and my surf wave is super clean.
