It is currently Thu Apr 16, 2026 7:49 am
 Post subject: 2012 Axis A20
PostPosted: Mon Jul 10, 2017 5:21 pm
2012 Axis Vapor Blue and White
Hours 360
Matching Vapor Blue 2012 Boatmate Single Axle Trailer with swing tongue and spare tire
Boat Options:
• Manual polished floating wedge
• Malibu Cruise
• Dual battery's with switch
• Fiberglass swim platform with surf cut out
• 2 fixed board racks
• Fatax folding tower
• Axis plug-in-play on top of stock hard tank ballast with the 4 stock switches on the dash. 2 x 400lbs rear bags, plus the front triangle 900lbs bag
• Stock ballast 900lbs + plug in play 1700lbs =2600lbs of ballast
• Sony head unit with the swim deck assessable rear controller. 4 rear Polk speakers 2 front Polk speakers 2 tower mounted MTX speakers. All 8 speakers Power by 2 4ch Power Acoustics amps on a very nice amp rack with room to add another amp for a sub if desired (not needed) Stereo is very loud and clear even at operating speeds.
• Tower mounted rear facing flood light wired to the factory accessory switch
• Factory trailering cover as well as an over the tower storage covers that covers the boat tower and the swim deck
• Has a wicked wake surf as well as a homemade surf gate that works amazing
Boat History and Hours:
• Boat was purchased by the first owner 5/26/12, and maintained each season by Skier's Pier, Including full documentation of maintenance.
• Logs shows 20 hour oil change and check-up, then seasonable oil changes with full documentation.
• First owner keep boat on a covered lift on a lake, and boat was stored indoors at Skier's Pier.
• Second owner purchased with 310 hours From Skier's Pier. At that time Dealer scanned the engine computer, and showed 265 hours were at 1200 rpms or lower! Boat was basically slowed cruised around the lake for most its life, and ended up getting traded in on a pontoon.
• Engine compression was also check at time of second owner purchase at 310hrs. All Cylinders were at 190-195
• Also at 310hrs the Tran's oil and v drive oil changed
• Second owner kept the boat on a covered lift for the 8 hours of ownership
• Oil was changed again when winterized at 318hrs, Also the belt and the water pump impeller was changed at this time as well
• I purchased the boat from the second owner in spring of 16. Previous owner was relocating to a different state for work and had to sell his boats and house unexpectedly.
Boat condition:
• Exterior is a 9/10 a couple very small imperfections some scuffs up by the bow stop that would buff off.
• Interior is a 8/10 it is in excellent shape. The rear seat back rest on the back side has a few Knicks in it from what I'm guessing is putting wake board or surf board on it and hitting it.
https://toledo.craigslist.org/boa/6213815684.html
19748541_10154783030473634_3251854571243940110_n.jpg [ 62.83 KiB | Viewed 24447 times ]
19732288_10154783030453634_3849700664772332134_n.jpg [ 93.24 KiB | Viewed 24451 times ]
