Axis Wakeboard Boat Forum http://wakeboatowners.com/ |
FS: OJ 945 Prop - $400 http://wakeboatowners.com/viewtopic.php?f=20&t=4454 |
Page 1 of 2 |
Author: | 80AMT23 [ Thu Nov 30, 2017 9:35 am ] |
Post subject: | FS: OJ 945 Prop - $400 |
Selling a barely used OJ 945 prop, I got this prop to try out last year and used it for about a month and half and didn't really love it for the weight I was running and then winterized the boat and the dealership was supposed to return the prop but then forgot about it and it was too late to return it so now I've been stuck with it. I had kept it as a backup just in case and never ended up needing it and now I want to try and ACME 3065 and want to sell this one. It's in excellent condition, maybe used about 8 trips out. $400 |
Author: | Bryan1 [ Thu Nov 30, 2017 11:06 am ] |
Post subject: | Re: FS: OJ 945 Prop - $400 |
What didn't you like about it? That was one of the props I was looking at. |
Author: | 80AMT23 [ Thu Nov 30, 2017 11:19 am ] |
So it's a very long story, but there ended up being a problem with my exhaust manifolds that was causing overheat alarms to go off, PCM tried to blame the prop(stupid, I know) and we've since figured out that wasn't the case, but my engine was running high RPM than it should be with the prop so it didn't work for me. I know there are several on here that run the 945 and theirs work fine and they have lower RPM than I was turning, but it turned out to be an underlying issue with my motor that's not relevant anymore because I swapped out for the 6.0 and the gearing is too low for that prop now. I was getting good plane times with heavier weight, just the RPM was higher than other 350s with that prop. I know Gibbs on here runs it with great success. |
Author: | nitrous1 [ Sun Dec 03, 2017 7:09 am ] |
Pm sent |
Author: | gibbs114 [ Sun Dec 03, 2017 10:37 am ] |
80AMT23 wrote: So it's a very long story, but there ended up being a problem with my exhaust manifolds that was causing overheat alarms to go off, PCM tried to blame the prop(stupid, I know) and we've since figured out that wasn't the case, but my engine was running high RPM than it should be with the prop so it didn't work for me. I know there are several on here that run the 945 and theirs work fine and they have lower RPM than I was turning, but it turned out to be an underlying issue with my motor that's not relevant anymore because I swapped out for the 6.0 and the gearing is too low for that prop now. I was getting good plane times with heavier weight, just the RPM was higher than other 350s with that prop. I know Gibbs on here runs it with great success. This is my favorite prop my T23 is a monster with it on there. Sent from my iPhone using Tapatalk |
Author: | dezul [ Fri Jan 12, 2018 10:19 pm ] |
I also run it on my '14 A22. Great prop. |
Author: | pickle [ Wed Jan 31, 2018 11:46 am ] |
still for sale? |
Author: | nitrous1 [ Fri Feb 02, 2018 10:22 am ] |
Must be, I sent 2 PM's and never got a response |
Author: | pickle [ Fri Feb 02, 2018 6:08 pm ] |
[emoji37] |
Author: | boardjnky4 [ Sat Feb 03, 2018 9:57 am ] |
He sold it to me, so I can say with certainty that it’s sold |
Page 1 of 2 | All times are UTC - 6 hours |
Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group http://www.phpbb.com/ |
