It is currently Sun Jan 11, 2026 2:54 am
 Post subject: OJ-TZX5 5-Blade Prop for sale
PostPosted: Mon Oct 22, 2012 10:51 am
I have an OJ-TZX5 5 Blade Propeller available for sale $400.00 (I really need to sell). Only used a few times out, and is in bran new condition. This propeller just did not work out for my situation A20 at sea level.
 Post subject: Re: OJ-TZX5 5-Blade Prop for sale
PostPosted: Tue Oct 23, 2012 4:07 am
Are you on Lanier? If so, full pool there is 1070'. Not high altitude, but not sea level, either. Otherwise, how much ballast were you running? My standard prop is marginal with my boat fully loaded, but I ski as well, so I don't want to put too much prop on it.
PostPosted: Tue Oct 23, 2012 5:55 am
When we looked at how much time we spent wake boarding, surfing, skiing, and my wife and I like to run to restaurants it just did not make sense to run the OJ. It does work as advertised when the boat is fully loaded, but we just do not spend a lot of time fully loaded.
PostPosted: Tue Oct 23, 2012 6:27 am
How did you pull it off? The standard puller barely fits the 4 blades without hitting the edge of the blades.
PostPosted: Wed Oct 24, 2012 5:41 am
I used a magnesium block, luckily it did not require a large tap.
PostPosted: Tue Aug 26, 2014 9:51 am
Still have this by chance ???
PostPosted: Tue Aug 26, 2014 3:53 pm
Wakerider, shoot me a pm if you don't get a response from OP.
PostPosted: Thu Aug 28, 2014 10:26 am
PM Sent boardjnky4
