It is currently Sun Nov 01, 2026 3:28 am
 Post subject: Replacing fuel filter
PostPosted: Fri Jun 14, 2013 11:41 am
Can anyone describe to me how to replace the fuel filter. Also should this be replaced once a year?
Thanks in advance
 Post subject: Re: Replacing fuel filter
PostPosted: Fri Jun 14, 2013 12:40 pm
I had looked at this last year when I thought I was having fuel issues. From what I could find our GEN 3 fuel pumps only need a replacement every 3 year or 300 hours (http://www.themalibucrew.com/forums/ind ... el-filter/).
Here's the part to use - http://www.bakesonline.com/detail.aspx?ID=1556
and instructions - http://www.bakesonline.com/images/2009/ ... n3pump.pdf
The fuel socks on the bottom of the pump assembly are part number 006069. There are what mine looked like after 250 hours.
PostPosted: Fri Jun 14, 2013 1:21 pm
not disagreeing with you Dave, if it recommends replacing it at that interval then its probably best, but I wouldn't mess the pump or the sock unless you had a problem. Do our boats have inline filters?
****EDIT****
Ok I see what your talking about now the piece in the top of the pump assy is the inline filter correct? do they have another filter someplace down line?
PostPosted: Mon Apr 04, 2016 7:10 am
Just a follow up to this, has anyone changed the socks yet? Did it make a difference?
I am experiencing a miss with full ballast and trying to pull someone. It sounds/seems to me like fuel issue. Maybe bad gas, maybe dirty filter.
Would this warrant buying the pressure regulator and filters?
