It is currently Fri Jul 03, 2026 7:26 am
 Post subject: Trailer lights
PostPosted: Sun Jun 16, 2013 6:15 pm
I found out today I have something going on with my trailer lights. I am not getting good connection to the truck because they are cutting on and off. Does it just need to be cleaned with something or could I have a short in the trailer? I don't think it is the truck new F250 no problems with other trailers. What do I need to do.
 Post subject: Re: Trailer lights
PostPosted: Sun Jun 16, 2013 6:23 pm
Look inside the folding part of the tongue, mine had a corroded connection that caused the left side to intermittently not work
PostPosted: Mon Jun 17, 2013 5:20 pm
I have check everything I know too check and have cleaned all connections everything is working now expect for the runway lights they come on for a second when first plugged in then go out.
PostPosted: Mon Jun 17, 2013 5:37 pm
Do they only work at night?
PostPosted: Mon Jun 17, 2013 6:34 pm
The runway lights are only supposed to work when the trailer is under water, there is a float switch back by the license plate
PostPosted: Mon Jun 17, 2013 6:39 pm
Mine have been working all the time til now.
PostPosted: Mon Jun 17, 2013 7:10 pm
Must be the new truck, something was causing mine to burn all the time before. Thanks
PostPosted: Mon Jun 17, 2013 7:12 pm
I wish mine would stay on all the time, I bet it looks cool going down the road with the hull lit up.
PostPosted: Mon Jun 17, 2013 8:17 pm
It is cool looking, I got used to seeing them on at night in my old truck, and now nothing.
PostPosted: Tue Jun 18, 2013 7:39 am
First thing I had the dealer do was over-ride the float switch to where they stayed on at all times. It looks sweet going down the road. I had a problem with my trailer brakes not releasing when backing and the lights going on and off. Turns out bad connection for the truck, the trailer was fine.
