It is currently Mon Jul 06, 2026 12:56 am
 Post subject: Need quick help!
PostPosted: Thu Apr 24, 2014 2:40 am
So today is the day I have waited for all winter! I am leaving this evening for Michigan to pick up the new boat. It is about an 8 hour drive.
Here is my question... What breaks come on the Axis trailer? The dealer says they are surge but the plug is a seven round. I don't have a electric brake controller and I don't want to drive up and find it has electric brakes. Thoughts??
 Post subject: Re: Need quick help!
PostPosted: Thu Apr 24, 2014 5:35 am
Every axis trailer I have seen has surge brakes. To verify, disconnect the trailer wiring and try to backup slowly. If the trailer resist you it has surge working brakes.
PostPosted: Thu Apr 24, 2014 6:26 am
No brake controller needed. Just a seven round
PostPosted: Thu Apr 24, 2014 7:01 am
Surge brakes. The 7-pin adapter is because you need the reverse lights hooked up in order to be able to drive in reverse.
The reverse light triggers a solenoid at the surge brake to disable the brakes when you're backing up.
PostPosted: Thu Apr 24, 2014 7:04 am
X4 on the surge. I don't think I have ever seen a tow boat on a trailer with electric brakes?? Even my 1990 Nautique had surge
PostPosted: Thu Apr 24, 2014 8:20 am
It's definitely surge even though it has the 7 round plug. I think they do that because the 7 round is a more reliable connector and most pickups are already setup for 7 round. Technically, 5 flat is all that's really needed here so they go overkill for whatever reason
PostPosted: Thu Apr 24, 2014 6:53 pm
Excellent! I am hitting the road right now. I thought it would be a 5 flat but I guess 7 round is becoming standard. Thanks for all the help!!
PostPosted: Thu Apr 24, 2014 8:21 pm
Electric brakes would rust up and cause all kinds of problems as soon as you dunk the trailer in the water, pretty sure all(or most) boat trailers are hydraulic brakes
PostPosted: Thu Apr 24, 2014 8:29 pm
all thats needed is 4 pin flat to a 7 pin adaptor but wire the blue wire to your reverse lights.= done
