It is currently Wed Jul 01, 2026 7:57 am
Post new topic Reply to topic  [ 268 posts ]  Go to page Previous  1 ... 20, 21, 22, 23, 24, 25, 26, 27  Next
 Post subject: Re: Aftermarket Wave maker
PostPosted: Mon Jun 09, 2014 9:38 am
can anyone walk or talk me throughout the drilling process?
PostPosted: Mon Jun 09, 2014 10:15 am
There's info on the drilling process on joes website. Took me a little longer then normal because I was so nervous of messing up I checked measurements at least 10-15 times before I drilled. If you need more info on the drilling process than what's on the website, I don't mind helping or I'm sure joe would be more than happy to help.
PostPosted: Mon Jun 09, 2014 10:19 am
Thanks Caliguy! whats the website?
PostPosted: Mon Jun 09, 2014 10:51 am
No worries man. It's wickedwakesurf.com
PostPosted: Thu Jun 12, 2014 9:37 am
Its been a bit since I posted on this. I made another set of gates and fiberglassed them. I used the LSV dimensions and kept my original length and tapered it as it was on the LSV. The result is better than I thought it would be. I've talked to Joe a couple times and we have shared ideas and thoughts. I've sent a couple people his way for sure. Def stoked with Version 2.0. Version 5.0 will be permanent mount lol
Last edited by SilverMustang35 on Thu Jun 12, 2014 9:40 am, edited 1 time in total.
PostPosted: Thu Jun 12, 2014 9:38 am
Additionals
PostPosted: Thu Jun 12, 2014 1:50 pm
Nice looking wave! What is your ballast setup for goofy side and are you using the wedge?
PostPosted: Thu Jun 12, 2014 2:05 pm
Thanks! im using factory, plug n play with 400lbs on each side, front bow sac, an additional 750 in the bow, and (2) 350s in the floor, wedge down, 10.6 mph. Those pics were with 2 total in the boat as well. Its beastly! That setup is for either side, nothing changes except the gate goes on the opposite side.
PostPosted: Thu Jun 12, 2014 8:40 pm
suction cup mount on your goPro?
PostPosted: Thu Jun 12, 2014 8:53 pm
My buddy's go pro but yeah he frankensteined a go pro to suction cup mount with a fail over tether if it comes loose
