It is currently Mon Jul 07, 2025 5:51 pm
[ 9 posts ] |
Author |
ridebutter
Post subject: Cruise Control Delay Posted: Mon Jun 16, 2014 12:31 pm |
Team Axis |
Just picked up my A22 on Friday, and I'm seriously impressed. Coming from my '09 210, I thought there would be things I missed, but so far I'm really happy.
One issue though, when trying to adjust the cruise speed there is a delay. It doesn't matter if we are at cruise speed, or sitting idle, the delay is the same. It is really annoying, and apparently there is a fix for it, but I'm not sure what it is.
Thanks!
_________________ Ridebutter Wakeboard School Cove Wakesurfers
Top |
away
Post subject: Re: Cruise Control Delay Posted: Fri Jun 20, 2014 8:07 am |
Team Axis |
Joined: Tue Aug 06, 2013 1:43 pm Posts: 62 Location: Harrodsburg, KY
what do you mean by delay? sitting idle? do you mean the time it takes for the number to change when you toggle the switch? When I toggle it is about a second per change or I can hold it down and it moves faster. Please elaborate and maybe some people can help you out.
_________________ 2013 Axis A22 Delta Universal Surf-Tab 750's rear lockers 950 Arrow under front seats stock tanks full
Top |
ridebutter
Post subject: Re: Cruise Control Delay Posted: Fri Jun 20, 2014 8:51 am |
Team Axis |
Yeah it takes a second when I push the switch, I have been on an older axis and it changes instantly. The tach just has a delayed response to the switch.
"Sitting Idle" I was referring to setting the speed before I went under power or changing the speed while under power, it makes no difference.
Top |
vanamp
Post subject: Re: Cruise Control Delay Posted: Fri Jun 20, 2014 1:42 pm |
Team Axis |
Same delay on my 2012 A22. Not sure why its delayed but im already used to counting my clicks.
Top |
Ferral
Post subject: Re: Cruise Control Delay Posted: Fri Jun 20, 2014 9:46 pm |
Team Axis |
Top |
ridebutter
Post subject: Re: Cruise Control Delay Posted: Fri Jun 20, 2014 9:52 pm |
Team Axis |
Top |
Fishn4four
Post subject: Re: Cruise Control Delay Posted: Mon Jul 14, 2014 5:49 am |
Team Axis |
Joined: Mon Dec 16, 2013 4:52 pm Posts: 170 Location: Tri-Cities, TN
I noticed that my 2014 T22 does the same thing. Sometimes it changes instantly and other times it takes forever for the changes to register. its when we switch from wake to surf or surf to wake that I notice it most.
_________________ 2014 Axis T22
Top |
DatTexasBoy
Post subject: Re: Cruise Control Delay Posted: Tue Jul 15, 2014 6:21 am |
Team Axis |
I have noticed with my 14' that you have to ease into the throttle especially at lower speed settings on cruise. I use to be able to gas it all the way and it would just pick it up on my 2010 but not on this one.
Try just using enough to get on plane and then give it a little more to set cruise.
Top |
ecore66
Post subject: Re: Cruise Control Delay Posted: Sat Aug 02, 2014 6:03 am |
Team Axis |
Top |
[ 9 posts ] |
Users browsing this forum: No registered users and 84 guests |
