It is currently Tue Jul 08, 2025 12:09 am
Post new topic Reply to topic  [ 69 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7  Next
 Post subject: Re: Post your wake/wave
PostPosted: Sat Jun 21, 2014 11:55 am
Getting that T22 Wave dialed in! Our team rider Vanessa was putting in work on this thing earlier this week
PostPosted: Sat Jun 21, 2014 12:09 pm
How was your T22 set up? I am still working on getting mine dialed in.... We were full ballast, wedge, p-n-p with 750s, 10.6mph 3 adults and 2 small kids. Had a good wave, but I would like to get it a little longer.
2018 T22
PostPosted: Sat Jun 21, 2014 2:11 pm
Raimie That wave is setup with...
Stock Ballast full
Sumo 900s in the rear
Sumo 650 under the bow seats.
FlyHigh 400lbs on top of the bow ( this will be switched to lead)
4-6 adults in the cabin including driver (slide the skybox seating to the center of the boat and sit there)
Surfgate out and probably 11.5ish mph.
Wedge deployed for surf and retracted for skim.
Takes a little playing around with but once you find the right weighting setup these boats are a monster wave and really fun to surf and transfer
PostPosted: Sat Jun 21, 2014 3:57 pm
I am new to this whole surfing thing so I was just wondering, why do u want the wedge down for surf and wedge up for skim??
PostPosted: Sat Jun 21, 2014 5:09 pm
ecore66 mostly has to do with rider preference. with the wedge retracted it keeps the wave more mellow and not as steep. Wedge deployed = steeper more of a lip.
PostPosted: Sat Jun 21, 2014 10:14 pm
Skim boards have less rocker than surf style boards and are more prone to pearling on steeper faced waves. Skim board riders tend to do more spins and surface tricks so the more face to the wave (less lip) gives them more room to play on.
PostPosted: Sun Jun 22, 2014 4:42 am
Stock Ballast full
Cool, thanks. What motor do you have?
2018 T22
PostPosted: Sun Jun 22, 2014 9:11 am
That T22 has the base 330 motor. You'd be amazed at what that motor can do when proped right. It also helps that he rides in the CA delta so elevation is not a concern
PostPosted: Sun Jun 22, 2014 8:18 pm
Working on getting ours dialed... its getting closer... I think we still need a little more weight.
I have the 330 and high altitude prop. It handles the weight better then I thought. Gets up to surf speed pretty quick and is able to maintain the speed just fine.
2018 T22
PostPosted: Sun Jun 22, 2014 8:48 pm
Not an Axis but had to share.
