It is currently Tue Nov 17, 2026 12:13 am
 Post subject: Axis Oil Change (drain plug?)
PostPosted: Wed Jul 02, 2014 9:20 am
Hey guys,
I tried to dig via the search function on the forum topics but couldn't find anything helpful.
I have a 2010 A22 (non-salt series) and looking for a easy method to complete an oil change. Is there a drain plug somewhere? I have a electric pump but it worked 1 time and now it doesn't pump anymore (even with hot oil) and I want to avoid purchasing a new 50$ pump - I want to do it the oil way (drain plug) if possible.
Let me know :)
Mike
 Post subject: Re: Axis Oil Change (drain plug?)
PostPosted: Wed Jul 02, 2014 9:46 am
On my '13 there is drain hose. Its secured near the top of the engine.
PostPosted: Wed Jul 02, 2014 9:52 am
I think that 2013's have many fancy new things that I don't have... unless someone can confirm that I'm blind and that my 2010 should have one :)
PostPosted: Wed Jul 02, 2014 9:56 am
Passenger side toward seat back is a 3/8 hose with a brass cap on it and it's clipped to the top bracket just behind the valve cover
PostPosted: Wed Jul 02, 2014 10:00 am
Nice nice - you made my day knowing that I won't need that darn dipstick pump! Do I need the oil hot to drain from there or is it possible to drain the majority in 30 degree weather?
PostPosted: Wed Jul 02, 2014 10:03 am
At the top of this picture where the paper tags are is where it will be attached
It's a hose screwed into the drain plug hole in the pan, I'm not sure if it will reach the bilge drain hole or not but it's worth a try.
PostPosted: Wed Jul 02, 2014 10:11 am
Awesome! I will check tonight. Thank you.
PostPosted: Wed Jul 02, 2014 11:02 am
Hope your drain hose is longer than mine. The end of the hose on my boat daylights flush with the outside face of the thru-hull. Makes oil changes extra fun. I shouldn't complain though, with the oil at operating temp it drained in under an hour.
PostPosted: Wed Jul 02, 2014 11:32 am
vacuum pump 50-100 dollars depending on size and shape. makes oil changes very easy ...... oil filter on the other hand is a little diff I always have trouble getting that off..
PostPosted: Wed Jul 02, 2014 11:49 am
FYI, dealerships pump the oil out via dipstick because it's easier and quicker. It's a one-time cost to just get the vacuum pump.
