It is currently Mon Jul 07, 2025 11:10 am
 Post subject: Adding more rack(s)
PostPosted: Thu Jul 10, 2014 7:49 pm
Wanting to add another board rack to the tower for a wider rack (a surfboard I use doesn't quite fit in the bottom portion of the factory racks)
What have people used that has a larger opening, but still looks similar to the factory rack? I don't need it to swivel like my others, but don't want it to look like some random thing I bolted on either.
A second questions is if people are adding single rack are they adding or port or starboard? Randomly was thinking about where it might get in the way less.
 Post subject: Re: Adding more rack(s)
PostPosted: Thu Jul 10, 2014 8:17 pm
I would put it on the opposite side that you dock on. So I think in most people's cases, the Port side because the boat pulls to the starboard side.
PostPosted: Thu Jul 10, 2014 8:28 pm
I use skylon racks on my 2013. No issues, good build quality. http://www.skylonsports.com/wakeboard-racks.html
PostPosted: Thu Jul 10, 2014 10:18 pm
My factory rack is the swivel rack and we have room in the top slot for our surf board.
If we had to add a rack and it wasn't a swivel rack I would definitely go to the port side. I would also consider adding it to the top spot and moving the swivel rack to the bottom in case we ever tied up with a lot of boats.
PostPosted: Thu Jul 10, 2014 10:38 pm
I wish, but the dumb triple x board is too thick!
PostPosted: Fri Jul 11, 2014 7:54 am
I ground down my factory rack with an angle grinder to get my triple x board to fit, No more rubber on the bottom but I just make sure I get the pad on the bare metal tines - be carfeul if you put the triple x in the rack for a long time it dents in a little - the dents seem to come out if they are not too deep. I'll take a picture tomorrow morning when I get the boat out.
PostPosted: Fri Jul 11, 2014 12:34 pm
Nice!
