It is currently Mon Jul 07, 2025 11:26 am
 Post subject: Loose swim platform
PostPosted: Fri Jul 25, 2014 3:53 pm
There is a lot of play on my swim platform. It probably raises up 1/2 when you wiggle it up and down. I know, very minor problem but it kinda bothers me. Any ideas on how to make the fit more solid? The bracket slips down into a metal pocket and the top is held on by pins. It looks like there is play on both the top and the bottom. 2013 A22. Thanks for any ideas.
 Post subject: Re: Loose swim platform
PostPosted: Fri Jul 25, 2014 6:33 pm
Is it the bracket itself moving or the piece in the bracket?
Ridebutter Wakeboard School
Cove Wakesurfers
PostPosted: Fri Jul 25, 2014 9:21 pm
Mine has a little bit of up and down play In it too, I think it's just a bit of slack in the bracket
PostPosted: Sat Jul 26, 2014 6:36 am
Mine (and all malibus i have ridden ) always has moved too.
PostPosted: Sat Jul 26, 2014 8:28 am
Every Nautique I have ever been on moved a little too. If it didn't, it would be certainly be jammed and difficult to remove. (As long as bracket itself isn't moving)
Cove Wakesurfers
PostPosted: Sat Jul 26, 2014 9:30 am
It's just the nature of the mounting brackets and pins. Unless you yourself bolt it on or fabricate the platform to the hull you're gonna to have some play.
Users browsing this forum: Google Adsense [Bot] and 60 guests
