It is currently Tue Oct 20, 2026 2:12 am
 Post subject: Ballast not staying full
PostPosted: Tue Aug 05, 2014 8:50 pm
I have a 2013 A22 vandall and when I fill my nose plug n play full it slowly drains out. Also my rear bags do the same thing but my center tank stays full the whole time. Which I would think it has something to do with my plug n play? No holes in the bags and it just started doing this the past couple trips. I've noticed on the drivers side where the holes are in the side of the boat there is a slow steady stream of water coming out of the middle hole. Has anyone had this problem? I was going to take it to the dealership just didn't know if it was something easy. Thanks in advance for everyone's help.
 Post subject: Re: Ballast not staying full
PostPosted: Tue Aug 05, 2014 9:13 pm
viewtopic.php?f=14&t=2502
My T22 is at the dealer this week with a proposed reroute to fix this issue. More to come....
2018 T22
PostPosted: Sat Aug 09, 2014 5:03 pm
Sounds like the bag is just siphoning itself out. You could probably fix that by adding a vented loop on the vent lines. There should already be vented loops in the back, make sure they got hooked up when your pnp was put in
PostPosted: Tue Aug 12, 2014 7:21 pm
I'm not a handy person but by chance could you pinpoint me to where I could find that? When I looked at my PnP all I see is hoses going in the floor from the bags?
