It is currently Sun Nov 15, 2026 9:27 am
 Post subject: Fixing a Crack
PostPosted: Wed Aug 13, 2014 1:17 pm
Anyone know how to fix this?
 Post subject: Re: Fixing a Crack
PostPosted: Wed Aug 13, 2014 9:11 pm
Are you planning on fixing yourself? If so, you're probably going to have to get the gelcoat color from Axis directly. That looks more like a gouge than a crack.
PostPosted: Wed Aug 13, 2014 9:44 pm
I just fixes a small nic in my gel coat used the spectrum gel repair kit from iboats I did a little writeup about my method near the end of this thread:
http://www.themalibucrew.com/forums/ind ... omsearch=1
If you end up doing it yourself let me know if you have any questions
PostPosted: Wed Aug 13, 2014 11:06 pm
I actually repair boats and cars for a living. Go to your dealer and get them to order the gel, the color is a really good match.
PostPosted: Thu Aug 14, 2014 9:42 am
Did you hit something? Or was there a bubble under the gel coat?
I would get the color from the dealer for an exact match.
PostPosted: Thu Aug 14, 2014 12:14 pm
Mine did that in almost the same spot and the dealer fixed it under warranty, it was like a bubble under the gel coat..looks good now!
PostPosted: Thu Aug 14, 2014 1:14 pm
Thanks for the info. Yea I was hoping to try and do it myself. I just bought the boat a few weeks ago and the boat came like that.
PostPosted: Thu Aug 14, 2014 1:30 pm
That was why I asked. If there was a bubble under the gel boat and it popped. then I would have the dealer fix it under warranty. I have seen that a time or two and both times the dealer fixed it under warranty. Almost around the same area. Check your warranty before you try and fix it yourself. I would not repair it myself since it is in a pretty visible area.
PostPosted: Thu Aug 14, 2014 10:15 pm
What year are those towers? Mine doesn't have those small bolts on mine.
PostPosted: Fri Aug 15, 2014 6:03 am
Mine's a 2011 A 20
