It is currently Sun Mar 29, 2026 1:12 am
Brandon161
Post subject: Re: New Axis Owner -Have some questions Posted: Sun Aug 10, 2014 11:14 pm |
| Boater |
Does anyone know how much the Axis wakeboard/surf board racks cost from the dealer?
dainbramaged
Post subject: Re: New Axis Owner -Have some questions Posted: Fri Aug 22, 2014 1:50 pm |
I have the same problem on the sun pads over lockers and engine (2011 Axis Vandall blk/blk pg4 one owner).... what I understand is that its a glue problem. Mine looks like someone spilled a gallon of pinkish/brown koolaid all over. The fix as I understand it is to keep cool. Mine sat inside for the first two years so I had no problem. I have tried lots of things(propping up cover/ white towels etc..) but to no avail. Embarrassing at times on cloudy day...doesn't go away quickly. When it first happened I cleaned it for hours and cussed quite a bit..........all I accomplished was sweating alot. Waiting for the day the sun doesn't make it go away............
_________________ 2017 A22 2011 Vandall
bmdupont
Post subject: Re: New Axis Owner -Have some questions Posted: Sun Aug 24, 2014 10:25 pm |
I have the same sun pad issue. Read here it was mildew but didn't make sense because it only shows up in the hot sun. I tried running my cover through the commercial washer and it still happened. Wish someone would come up with a solution, my boat stays outside when it's nice out.
ac88926
Post subject: Re: New Axis Owner -Have some questions Posted: Mon Aug 25, 2014 12:24 pm |
Joined: Tue Apr 08, 2014 8:06 am Posts: 148 Location: Lebanon, TN
I was told the problem with your vinyl turning purple/brown is from the heat buildup/contact with the cover. It draws out the glue/impurities in the seats to the surface of the vinyl and discolors them. The sunlight will pull it out over time but it sucks. I used to have the same issues with my vlx. My 14' axis came with a grey cover to remedy this problem. So far, so good
nebwake
Post subject: Re: New Axis Owner -Have some questions Posted: Wed Aug 27, 2014 3:13 pm |
| Boater |
I have that same problem on mine, and mine sits in the garage with the cover on to keep the dust down. What I did is take hydrogen peroxide (3%) rub it on the seats where the stains are and set the cushions in the sun for 2 days. So far so good, we'll see if it re-stains but its been 2 weeks with no more pink stain! I was concerned about the peroxide damaging the stitching, so I made sure to not get any peroxide on the stitching.
bmdupont
Post subject: Re: New Axis Owner -Have some questions Posted: Thu Aug 28, 2014 10:51 pm |
Users browsing this forum: Majestic-12 [Bot] and 65 guests |
