It is currently Thu Nov 12, 2026 12:27 pm
 Post subject: Hot Water Shower Kit
PostPosted: Sun Dec 14, 2014 8:45 pm
I am looking for a hot water shower kit if anyone knows of a good solution. I have an 2014 A24 with the factory installed heater. I was hoping that I could connect into the hot water hose to the heater and cold water input hose. I would like to install the shower hose and temperature controls under the rear sundeck.
Does anyone have a shower kit that they would recommend or ideas how to do this
Thanks
Jim Fuller
Lake Keowee, SC
2014 Axis A24
Boat Name: Who's Next
 Post subject: Re: Hot Water Shower Kit
PostPosted: Mon Dec 15, 2014 11:40 am
I would really like to add one to mine too. Trying to decide to go cheap with a DIY one like this http://www.wakeworld.com/MB/Discus/mess ... 1065589943
Or go with a nicer heatercraft like these
http://www.heatercraft.com/marine-deck- ... with-pump/
http://www.heatercraft.com/marine-showe ... -pump-new/
As far as connections, you could easily tap off heater connection, and then a T after the raw water pump.
PostPosted: Tue Dec 16, 2014 9:16 am
We did a group buy last year on heaters and showers from Heatercraft. I went with both.
I can take pics of my install if you need them.
PostPosted: Tue Dec 16, 2014 9:38 am
Hey Team Axis
When you get a chance, could you take few pictures of your installation. Where did you mount the pump? Where did you mount the hot and cold valves and sprayer hose? I want to mount them under the swim platform if possible and not cut a access hole in the back of the boat for the sprayer hose. I am looking for ideas before purchasing the heater craft kit
Thanks for your help
Jim Fuller
Lake Keowee, SC
2014 Axis A24
PostPosted: Tue Dec 16, 2014 10:33 am
Hope this helps. Can get more this weekend if you want me too.
