It is currently Mon Jul 07, 2025 7:05 pm
 Post subject: 2015 Axis PnP rear drain line
PostPosted: Wed Dec 17, 2014 9:55 am
Haven't noticed yet but of the 2 drain lines in the rear locker is the drain line near the transom still NOT all the way back against the transom or is it like the 2014's where it comes out of the floor about 8"-10" from the transom wall and not allowing the sacks to slide as far back as possible in the compartment?
 Post subject: Re: 2015 Axis PnP rear drain line
PostPosted: Wed Dec 17, 2014 10:37 am
AJ....
Have one of the Texas Malibu guys pull the hatch and snap you some pictures. I am sure they will have no problems doing that for you. since you might have the bug for a 2015 already.. :)
you might have an Axis addiction problem!!!
PostPosted: Wed Dec 17, 2014 10:56 am
It is set up similar to last year, however this year they do include the fittings attached to the hoses for the rears. This picture if from a T22, but our A24 is set up the same way along with another T22. The rear drains include the Strait Quik Lock adapters while the rear fills have a 90 degree elbow Quick Lock. The bow PnP is the same as last year where the lines are tied into each other.
PostPosted: Wed Dec 17, 2014 11:20 am
It should come like this after I modified mine. This way you can slide the sack all the way back and/or get those 750, 900, or 1000 sacks to fit easily without pulling out the fitting and dumping all that ballast into your bilge.
PostPosted: Wed Dec 17, 2014 11:25 am
Easy, fast mod to correctly fit the larger sacks. Remove small cover over rear drain line, spin the drain line 180 degrees, trim a few inches off the hose, silicone two 90 degree elbows, and you're done. This pic just shows one of the 90 degree fittings. The top pic shows both 90 degree elbows.
PostPosted: Wed Dec 17, 2014 11:27 am
Ed, I really like my A24. I think I'll keep it for at least 2 years lol
PostPosted: Wed Dec 17, 2014 11:35 am
The 2015 A22 I saw at Surf Expo had the connections all the way at the transom.
Ridebutter Wakeboard School
Cove Wakesurfers
