It is currently Sun Oct 18, 2026 1:55 pm
 Post subject: DIY LEDs in your boat.
PostPosted: Sat Aug 07, 2010 8:50 pm
Anyone put LEDs all in your boat? If so what company are you getting them from? How are you installing them.
 Post subject: Re: DIY LEDs in your boat.
PostPosted: Wed Jul 06, 2011 4:00 pm
Wanted to put this link in here so I can find it again. Looks like a direct replacement.
http://www.walmart.com/ip/Attwood-LED-Mini-Courtesy-Light-Red/14150836?sourceid=1500000000000003260410&ci_src=14110944&ci_sku=14150836
PostPosted: Fri Jan 20, 2012 8:03 pm
picked these up at Advance auto, have all different lengths, and they have double sided tape already installed and they can be cut to length, I used the 36" strips on each side, they were about 35$ a piece, the individual led's are 10$ for a pack of four and they fit perfect in the drain holes for the cup holders
PostPosted: Fri Jan 20, 2012 8:05 pm
more shots, I just couldn't make myself pay 400$ for the acrylic rings to go around the cup holders so I improvised
PostPosted: Fri Jan 20, 2012 8:08 pm
more
PostPosted: Fri Jan 20, 2012 8:12 pm
they also had the exact same ones that came in the boat but were currently out of the red ones, they have a few different colors in house, blue, green, red, white, pink, and some color changing ones too.
PostPosted: Sat Jan 21, 2012 8:49 am
Nice job Walter. I was looking at these http://www.superbrightleds.com/cgi-bin/ ... xible.html
Did you splice into existing wiring for interior leds?
PostPosted: Sat Jan 21, 2012 9:10 pm
yup, for the cup holders I tied the wires to the little white light above them on the removable panel, the ones under the seat cushion I tied to the forward LED that was already under the seat, just pulled out the existing light and put the wire through the hole and pushed the light back in, the wires were like 18 gauge so they were thin enough to fit with ease, that and I didn't want to drill a hole in this thing for two tiny wires
PostPosted: Wed Feb 15, 2012 9:01 pm
Just finished the sub for a whopping 35$ woohoo
PostPosted: Wed Feb 15, 2012 9:39 pm
Walter- are your leds that came with the Axis white?
