It is currently Fri Nov 06, 2026 8:33 pm
 Post subject: 2016 A20 light bar and tower speakers help
PostPosted: Thu Jan 28, 2016 4:54 pm
We got a 2016 A20 this past fall. I was wondering about adding a light bar and tower speakers and wanted some advice.
For the light bar i was looking at something like this:
http://www.amazon.com/gp/product/B00KQXKG46?psc=1&redirect=true&ref_=ox_sc_act_title_3&smid=ASZPS6VGQ8JST
This one seemed to have good reviews but there are a lot of similar products that have bad reviews. I have also seen some more legit ones that are around the $500 price range, like from rigid. Is there anything in-between that you would recommend. I definitely dont want to spend $500+ but would be happy to spend around a $100 if it was a lot better than the $40 one on amazon.
I also was wondering about install/wiring. Are these boats setup so that it makes it easy to add on stuff like this or do i need to be a electrician to do it? I know the dash has a spot to add tower lights but my extent of electrical work has been to had extra home outlets. Any advice would be great on the option of wiring it myself.
On to the tower speakers. I know the HLCD is the greatest thing ever but i dont have any interest in sending music 80 feet down the line. Just something basic to add another level of sound in the boat.
I was looking at something like this:
http://www.ebay.com/itm/Krypt-Wakeboard-Tower-Speakers-Marine-Boat-UTV-RZR-Polaris-Can-Am-Jeep-Roll-Cage-/331178972835?hash=item4d1bce16a3
Is there something else i should be aware of in a similar price point of around $200?
I also wanted to ask about wiring tower speakers. The 2016 has some type of sound hub box by the batteries. Is it easy to add an amp and speakers or is there quite a bit more to it and i should leave it to the pros. I noticed on the head unit that there are some controls for tower speakers so i was hoping it was easy to add on to. Since i am not trying to do anything too crazy i was hoping i could do the installs myself. Any advice, walk-throughs, tutorials, video links would be greatly appreciated.
One last question with the way the bimini stores away to the tower. I was wondering if there are any problems or tip with adding things to the tower with out interfering with the bimini process.
Thank you in advance for any assistance.
 Post subject: Re: 2016 A20 light bar and tower speakers help
PostPosted: Thu Jan 28, 2016 8:27 pm
I also just bought a 2016 A20 and did sound pack 1 with just the 4 rear speakers and the kicker media center. I don't believe the tower is pre wired for light bar but the tower and bow are both pre wired for speakers. I've already added the bow speakers and wired my 4 Rev8s to the tower. You should have received a manuel for the kicker media center that shows you all the outputs this thing has. Zone 2 can be named Tower so when you push in the main knob it switches from main volume to zone 2 and let's you have separate volume control. You will also need a bigger amp board then the one that comes with sound pack 1. The board that comes with sound pack 2 is big enough for everything that's already there plus 2 more amps.
PostPosted: Fri Jan 29, 2016 2:04 pm
One thing y'all have to think about is the clamp size on these towers. A lot of the less expensive tower speakers won't make a clamp large enough for our tower.
As for the light bar I've had great success with the cheaper brand. I don't see any reason to spent $400 more for name brand.
PostPosted: Fri Jan 29, 2016 3:01 pm
My expirenc even with light bars, you get what you pay for. Although they cheap ones look similar, they are far from it.
To put it into perspective. I have a buddy with a 50" dual row eBay light bar in his truck, I have a 24" single row pro comp light bar (equivalent to rigid) and both put out the same light output side by side. It is a noticeable difference when comparing the same sizes together. IMO, just spend the money on the high end lights, expesially for marine. You'll be glad you did.
